vaSel... commands should add to selection, not clear it
Hello!
I’d like to select all VA walls plus all VA slabs in my scene, which is kind of a problem, since the vaSelXY commands clear the previous selection.
This is somewhat agains Rhino conventions - new selections always add, never clear.
Could we have the same behavior, please?
Thanks!
Best regards
Eugen
Hi Eugen,
We can change that so VisualARQ selection commands do not clear previous selection. I’ll let you know when we implement this feature.
Thank you, Francesc! Would make sense, right?
Since there are no ‘saved selections’ in Rhino, it would be the only way to select, say, all vaWalls and all vaSlabs.
Yes, it makes totally sense, and it is the way Rhino selection commands work. So we will change that for VisualARQ selection commands too.
Hello!
This is still pending, right? Still not working in 2.6.1.13623.
Thanks!
Hi, yes this is still pending, we will let you know here when it is available.
Hi @Eugen ,
This issue has been fixed in the new 2.7 version.
Kind regards
Thanks, that comes at a very good time… (working hard on my diploma at the moment, using VA).
