Hello!
Sometimes, when using vaSectionAddJog multiple times, the previous added point (jog) disappears.
Is this a bug?
Repro: just create a vaSection, then ‘play’ with adding jogs.
A question: is it possible to remove jog points? Del key does not work.
Thanks!
Ok, I could reproduce it now. It looks like it is happening only when using object snaps, so as a workaround you can do it without using them for now but I’ll report the bug to find a solution.
Ok, I’ll report this issue as well but take into account you can assign an alias to any command:
