All pieces are cutted at home using my Gweike M3 pro with a 1200 W fiber laser. There is 151 m of cutting that takes more than 4 hours, due to the circle holes, a bit less than 3900 !!
That’s beautiful, excellent work. Love the shadows it creates! Maybe since it creates groups of point lights, something star or constellation related would work for a name?
Thanks, good idea and very good catch, I live at “constellation street and stars street” translated, it is in French indeed! My address is not a secret as it is everywhere in business directories !
These are beautiful!¬ I’m intrigued to know what the failed attempt in wood was!
I had a thought that you could easily 3d print the individual pieces and make some kind of PLA rivet to fasten them all together.
The laser cut metal looks premium though!
It was this project that failed. It was quite a volume with a single layer so at the connexion there was an overlapping which lead to slight geometric change and at the end no possibility fix the last pieces.
I am now on the second iteration for this lamp. Now the middle hole to place the bulb socket exist already. During the first iteration I cuted the hole after fabrication using the CNC and laser (not so easy and precise).
And always a little pdf with images, not very useful for this design as the number of piece is limited and easy to find using just the 3d model. Here just 42 pieces (Answer to the Ultimate Question of Life, the Universe, and Everything)
