VariableFilletSrf surface selection
I am having a problem with VariableFilletSrf. It was working fine in previous Beta versions but now it is not picking up all of the surfaces along a curve and there is no option to select surfaces manually. VariableFilletSrf.pdf (561.9 KB)
The command will only work on two surfaces not polysurfaces. Can you post the model where it was working the way you want? Also post the one where it’s not that you’ve referenced in the PDF too please. I’m not sure what the difference in geometry was but the command appears to be working correctly here.
