I have an issue with data stream matching. How do you combine two lists into one with variable output?
For example, if my inputs are a list with two branches - 42 and 43 values respectively and 16 branches with one value each, how could i change the input B (curve) to make my outputs 42,43,42,43…, instead of 42,43,43,43…
Thanks in advance!
Karlis
