Variable radius fillet edge
Hello, I am looking for some insight on how to accomplish variable radius edge fillets on the green marked holes. I’ve tried a couple different approaches and not quite getting the result I’m looking for. The top of the holes need to have a larger radius than the bottom. Thanks in advance.
  • Pat
Please share a file, this will help getting you the right advice.
You can take shape geometry than middle of the way end of the way or how many specific points you want to change in you’re hole than connect these curves with subdloft
Snout_EdgeFillet.gh (11.6 KB)
I’m not able to upload the actual file due to privacy restrictions, but this attached file is similar.
Commenting to hopefully get a little bit of a bump. Hoping somebody can share their approach to accomplishing this.
Thanks
