Hi!
I have found a small but weird issue while developping a variable input parameter component. I basically want to always have a “free” input, as does Merge component for example.
As per David’s explanations here, i do a basic check during VariableParameterMaintenance function,like this one :
Public Sub VariableParameterMaintenance() Implements IGH_VariableParameterComponent.VariableParameterMaintenance Dim num2 As Integer = (Me.Params.Input.Count - 1)
Dim i As Integer = 0
Do While (i <= num2)
Me.Params.Input.Item(i).Name = $"Data {(i + 1)}"
Me.Params.Input.Item(i).NickName = $"D{(i + 1)}"
Me.Params.Input.Item(i).Description = $"Data stream {(i + 1)}"
Me.Params.Input.Item(i).Optional = True
Me.Params.Input.Item(i).MutableNickName = True
Me.Params.Input.Item(i).Access = GH_ParamAccess.tree
End If
i += 1
Loop
If (Me.Params.Input.Item(num2).SourceCount > 0) Then
CreateFreeInput() ' add a free parameter if last input is used is full
End If
End Sub
Private Sub CreateFreeInput()
Params.RegisterInputParam(New Param_GenericObject())
End Sub
Problem is, whenever an input is added, I can see it but I cannot connect anything to it until document has recomputed : the wire doesn’t ‘stick’ to the input.
Does anyone know what additional step I should perform to make this input ‘connectable’? A call to ExpireSolution may work but it sounds a bot carpet bombing to me
Thanks for your helps
