I need to increase or decrease the number of inputs in a Node. Same as the node merge or the node Entwine in GH. So when you press (+) you have another input and when you press (-) you cancel that input.
Thank you very much David, runs smoothly.
There is a way to refresh the rendering node after delete an input.
although it happens as soon as you “touch” the input.
