Is there a way to input a variable into text element?
For example, I’d like to create several different named layers, changing these numbers
concatenate_text.gh (7.8 KB) Sure. You should use concatenate to put together different strings. You can input a number, for example from a series component and create lots of different names.
Here are some examples:
To add inputs to a concatenate component just zoom in and use + and -
You will find everything you need to work with Strings in Sets > Text
Thanks Guys!!
