Good morning friends,
Looking at Help notes for VariableFilletSrf and wondering if there is a trick to selecting the handle to edit? I click on it and nothing happens.
Thank you.
Cosmas
Thank you.
Cosmas
Hi Cosmas - currently you do not get to move the default handles at the ends, only added handles. You can monkey with the radius but not the location of the two ends.
Hi Pascal,
I hear you, but I don’t seem to be able to grab the added handles either. To select them, do I click on the little square at the end of the handle? Nothing seems to happen: )
Thank you.
Cosmas
Hi Cosmas - it is a little fiddly, especially on a higher resolution monitor, but at the base of the handle, in the apex of the angled lines, there is a blip that shows up if you get near it with the mouse - that is the thing you can drag.
I hover carefully at the apex of the angled lines and – still no blip. I made a little one minute video hoping that we can figure out what I’m doing wrong. Thank you, Pascal:
I see that… I am not sure what to suggest. Try in wireframe display mode, maybe?
No blip in wireframe.
Pascal, by “Blip” you mean a visual flash? Or an audio blip? Can you make me a video?
Hi Cosmas- a point that shows up when you get close - you can cick on that and move things. Are you able to drag the radius out at all? I’ll make a clip in a bit here.
@cosmas here is what I see-
The ‘blip’ is the little cross-hair that pops up in the tiny handle point when your cursor gets near - that means to can click and drag.
Pascal
