Is it possible to get the Variable Radius Chamfer command to produce different leg lengths on the chamfer as you would do on the Chamfer Curve or Chamfer Surface.
Thanks
James Crombie
Thanks
James Crombie
Hi James - ChamferSrf has two distances as inputs… the wish is on the heap for ChamferEdge.
http://mcneel.myjetbrains.com/youtrack/issue/RH-26549
thanks, Pascal
Pascal
Thanks, I know about the ChanferSrf but it gets messy with multiple
surfaces with a lot of trimming/joining
Another similar feature would be to do the same thing with the
VariableFilletRadius like this screenshot. I can get a similar effect using
MoveEdge, which is fine on one edge but gets messy when doing several that
connect as in the second screenshot.
thanks
James Crombie
Design Engineer
Tel: 902-838-7011 ext. 211
Fax: 902-838-2833
http://www.marinenav.ca https://www.facebook.com/MarinenavLtd
skype:harold.marinenav?userinfo
This e-mail is confidential, may contain proprietary information of
MarineNav Ltd. and/or its operating divisions and may be
confidential or privileged. This e-mail should only be read, copied,
disseminated and/or used by the addressee.
If you have received this message in error please delete it, together with
any attachments, from your system.
<img src='//global.discourse-cdn.com/mcneel/uploads/default/original/3X/7/d/7de2bcde8a5adb24a10be13d601426db5bbcfdc8.jpg' width='216' height='56'>
<img src='//global.discourse-cdn.com/mcneel/uploads/default/original/3X/9/e/9ed3b9b056366b415ca92d966c2a0b3229a822c6.gif' width='58' height='58'>
<img src='//global.discourse-cdn.com/mcneel/uploads/default/original/3X/1/e/1ecef9f26a05fa560d3c913500c5a55d57ab4f0c.jpg' width='583' height='500'>
<img src='//global.discourse-cdn.com/mcneel/uploads/default/original/3X/1/9/19c2dd42ad8c25eefd87fb3bbee56167db53d352.jpg' width='583' height='500'>
