Vanishing buildings - rh 7
hi, after creating a building model in rhino 7 , saving and closing, then reopening -a part of the the polysurfcess are missing but still can be seen as a “ghost” (see attached pic) and cant be selected.
(i should say that before closing the document i did extrude face to the bottem of the polysurfeces)
love your help on how to restore to normal.
Can you post you file, then others and myself can take a look to see if we also experience this problem.
Its also nice to post your Systeminfo. Run the command in rhino and copy-paste the results. The McNeel can help you.
See: Please read this if you are logging a bug or issue
model3.3dm (17.2 MB)
Rhino 7 SR1 2020-12-8 (Rhino 7, 7.1.20343.09491, Git hash:master @ 350b20978b4fcd75493212fbd3c4248983612f86)
License type: tion, build 2020-12-08
License details: Stand-Alone
Windows 10.0.19045 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3070 (NVidia) Memory: 8GB, Driver date: 6-6-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.19
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 1GB, Driver date: 11-7-2023 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-6-2023
Driver Version: 31.0.15.3619
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.1.20343.9491
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.1.20343.9491
I’m not seeing the left building at all, the right one seems fine to me.
I did see that you have alot of open non manifold polysrf’s.
You can use commands like Cap to close these (The Cap command fills planar holes in objects with planar faces).
If the building really is gone you might need to retrieve it form an autosave?
c:\users[username]\appdata\local\McNeel\Rhinocerous\7.0\Autosave
Maybe update Rhino to the latest, you’re on 7.1, the current version is 7.36…
… if you can, the license type looks suspect.
