Hello Rhinos,
I work daily with Visual Arq and Rhino 8, often using the vaExportToDWG command to export a layout with all layers as a DWG, and then continue working in Illustrator.
However, when I set up an Isometric View in the layout, the lines are no longer exported, but instead, a .png file is created and saved in the .dwg. A workaround with Make2D is of course possible, but it has some disadvantages.
Maybe this is a bug, or is it just me experiencing the problem? If anyone cannot reproduce the issue, I can upload a demo file.
Looking forward to hearing from you.
Best regards,
Leonard
