VA3 - Error importing IFC-File
Hi together, I tried to import a IFC - File with the VisualArq-Importer (rhino7, VA 3.9.0.14860, standalone licence ) and got this error…
Importing with another app works perfectly (so no problem within the file), maybe it’s a problem of the “Licence Warning”?
Hi @Thomas41 Can you open the file with the V3 Engine?
If you go to Rhino Options > plugins > (plugins that do not ship with Rhino), and enable the IFC Import Plug-in (V4 Engine), can you then open the IFC file with the V4 Engine?
If you share the IFC file I can test this on my end.
Which VisualARQ version are you using?
Hi Francesc, yes that worked, thanks a lot!
Visual Arq 3.9.0.14860
