VA3 Bug - Guide control points can not be selected
Once Guide is created, it cannot be modified through control points, as the control points are un-selectable.
Steps:
  1. Create a new Guide object
  2. Put on ControlPts (_PointsOn)
  3. Try to select the visible control points - not possible
Rh8 SR30
VA 3.10.0.14876 (2026/04/01)
Hi @Toni_Osterlund, I can’t reproduce this error:
GUIDE
Can you share your file?
Is it possible that you can’t select the point through cross box selection? I see this doesn’t work. But selecting the point by picking it, it should work.
@fsalla
You are correct - point picking does work, cross box does not.
I discovered this while attempting to move several Guides at the same time. Didn’t occur to me to point pick.
There’s still a bug in point picking as well, when picking multiple points.
See Video below
All right, I’ll report these bugs.
@fsalla @Toni_Osterlund I’ve not yet tested the new RC or the 3.9.1 but from recent experience, without knowing exactly how to reproduce it at the moment, I was not able to select and move an end of a guide by clicking on it. I believe that it was about how the guide was created, by creating from curves or not. As far as I remember in some projects, from curve guides, could not be edited from grips. I am going to check it.
