VA2 - Prevent windows from locking to a wall
Hi there
I am looking for a way to prevent windows from “locking” on to the nearest wall. I have a sectiondetail (see picture) where the window comes in front of a short base wall. The window is made with a custom gh-style while the wall is just a normal vaWall. Currently if I place the window in front of the wall, the wall disappears. I tried custom opening profiles but those didnt really work. If I put the windows in a separate Block it kind-of works but if I edit the block it tries to move them back into the wall.
Is there a good way to prevent objects from interacting with each other?
Hi @phhs,
You can achieve this by defining an apropriate window alignment and window alignment offset. For instance, in the following example I changed the window alignment to exterior first:
Then, I changed the window alignment offset as 0.135 m. This way I am telling the window to separate 0.135 m from the wall exterior boundary where it is aligned:
Also, if you want to make sure the window doesn’t perform a hole in the wall, you can define the window cut depth as “None”:
Here you have the file I used: Window.3dm (2.8 MB)
Perfect, thanks a lot!
