va.SetBeamProfile() Changes Doesn't Update The Beam Style parameter
I am trying to update ARQ beam profiles with C# code using va.SetBeamProfile(). The problem I am having is that the profile parameter will get set correctly in the Properties: Beam panel but the corresponding Style parameter will not change and I don’t see any other method i.e. va.SetBeamStyle() that will get the Style parameter to update. Any help would be greatly appreciated. Thanks
Hi @patskorut,
To get/set the style of any VisualARQ object, you need to use the methods GetProductStyle and SetProductStyle.
Enric
