Va-related memory skyrocketing in project
Opening my project without Va active, my memory use rests around 4 GB. With Va loaded, the memory steadily climbs to about 16GB until this project crashes. I don’t think I am using Va differently from a project of similair size and complexity.
I sent a link to the project identified above. I will really appreciate your help troubleshooting this. I may need to reduce the number of details with active VaSections, or perhaps you’ll have another recommendation.
Since sending that link yesterday I have simplified the project in various ways, with very limited success.
I believe that the most recent Rhino update is unstable with VaSections
Hi @djhg,
I’ve already answered you by email regarding this issue.
Thanks,
Enric
Yes, thanks.
The problem continued, so I have converted the problem project to non-parmateric Rhino objects so I can work with it.
From less drastic problems cropping up in another project, I think the issue is with Hidden display mode with active VaSections. It appears that if I turn off the Hidden display detail views, problems go away.
I need to turn them off to print, because though they display as Hidden line mode, they print as Wireframe.
Hi @djhg,
I have sent you a new email requesting more information about this issue, as I’m still unable to reproduce it with your 3DM.
Thanks,
Enric
