Is there any plan to make VA objects associated with dimensions?
Osnap does not work with center of walls. I think this is also big issue.
Thanks
Hello @archist97,
Yes, we have plans to have dimensions linked to VisualARQ objects. We will keep you posted about this. As for the Osnap issue, I cannot reproduce it. Could you show me an example?
Osnap has no issue. What I mean is Midpoint Osnap doesn’t work with “Center of Walls.”
Midpoint works with only mid-point of each wall layers.
Hello @archist97,
I guess you need this, for example, in cases like this one to choose the midpoint of the selected wall instead of the midpoint of the wall layer. Is that correct? If this is what you mean, I am not sure if it will be possible as Osnap is a Rhino feature, but I’ll see if there is something we can do from our side.
Hello @archist97,
Ok, so you need to have the axis of the wall available for snaps. I guess you are interested to have this wall axis displayed in the views in some cases as well, aren’t you?
Yes. Something lie that. Actually, we are already having wall center line created automatically through grasshopper. We are also using this for room area calculation. You can do that with “Space”, but you can’t calculate room area with wall center line. And these center lines are used for area calculation drawings for building permit. It would be really handy if VA could offers this feature. I attach GH file.
Thanks.
Wall Center Line.3dm (3.8 MB)
Wall Center Line.gh (27.7 KB)
Hi @alfmelbev . Do the dimesnions linked to VA objects be released with VA3? If not this feature should be utmost priority!
Hi @asisintel, unfortunately, we haven’t been able to solve this yet, so it won’t be ready in VisualARQ 3. We will keep you posted.
Thanks for the info @fsalla. Wish to have that asap. Will there be VA3 notification with new features on the website for us to know new capabilities?. When shall the wip version will launch?
Yes, we are working on a new page that will show the most relevant new features in VisualARQ 3. The WIP version will be released in a few days.
