VA Exported DWG Doesn't Match the Selected Layout
I’m trying to understand how vaExportToDWG is supposed to work.
I have a Rhino Layout displaying a floor plan and annotations at a defined scale, with dimensions placed directly in the Layout.
When I run vaExportToDWG, the command asks me to select which Layouts to export. I select Page 1, but the resulting DWG appears to contain geometry from the Model Space rather than the actual drawing shown in the selected Layout.
In fact, the exported geometry closely resembles what I see when switching to the top view of the highest building level, not the floor plan displayed on Page 1.
Since Rhino already provides native DWG export, I would expect vaExportToDWG to preserve the selected sheet’s composition, scale, annotations, and visual representation, while converting VisualARQ objects into standard DWG geometry.
Otherwise, I’m struggling to understand what advantage this command provides over Rhino’s native DWG export.
Is this the intended behavior, or am I missing something?
I also tested vaExportToDWG in Rhino 9.
The exported VisualARQ geometry looks significantly better than in Rhino 8, but dimensions placed directly in the Rhino Layout are still missing from the exported DWG and the exported composition still doesn’t match the original Page 1 layout.
I also found a related discussion reporting similar issues:
[VaExportToDwg still unreliable and confusing (3.3 RC1)]
It seems that at least some of these issues have been reported before. Are they still being worked on?
Here I provide all my test files:
page1 export.zip (540.3 KB)
building-r9.zip (5.2 MB)
building.zip (6.9 MB)
Hi @badileanu
This is what the command does.
But in this case it looks like the DWG export fails when there are hidden levels between the level you are displaying and the levels below. We will fix this in VisualARQ 3.13.
If you hide the upper level (“Level 03”), the DWG result will be consistent:
The position of texts and dimensions in the exported DWG is something we are currently revising.
and thanks, Francesc. I understand the issue with hidden levels, just to clarify, my main concern is that dimensions placed directly in the Layout (Paper Space) are missing from the exported DWG, not just incorrectly positioned.
Is this also covered by the revision you mentioned?
@badileanu this is something we are currently revising too. I’ll keep you posted!
This issue has been fixed in the VisualARQ 3.13 RC2: VisualARQ 3 - Version 3.13 RC2 released
This problem is fixed too in the VA 3.13 RC2
Thanks, Francesc!
I’ve tested this with VisualARQ 3.13.0.14640, using the default export settings, but the issue still persists.
Dimensions placed directly in Paper Space are completely missing from the exported DWG, while dimensions from Model Space are exported with incorrect scaling.
I’ve attached screenshots showing the original layout and the exported DWG.
Could you please try it with the 3.13 RC3? VisualARQ 3 - Version 3.13 RC3 released
I may have pointed you to the wrong version where this was fixed, before.
Hi Francesc,
I’ve tested the export again with VisualARQ 3.13 RC3, using the default settings, but the dimension scaling issue still persists.
I’ve also checked the exported DWG in both BricsCAD and Autodesk Viewer.
Interestingly, dimensions placed directly in Paper Space appear correctly in the exported Layout when opened in BricsCAD, but they are not displayed in Autodesk Viewer.
However, dimensions originating from Model Space are severely oversized in both applications.
In BricsCAD, one of these dimensions has an arrow size of 3 and a dimension line extension of 1.500 m, which suggests an issue with dimension style scaling or unit conversion during export.
I’ve attached screenshots showing the results.
Just chiming in, when I was trying to get the VaDwgExport to work, I got much better results if I used dimensions without any annotation style overrides. That means, just like they were set up in Options/Annotation styles, with no unique parameter set up in dim object properties panel.
If I remember it correctly, then they began to export very fine. But I ran into other export problems quickly and stoped using VaDwgExports since (it’s been about a year, I think). I was hoping it is in a much better state now…
@badileanu What Rhino version are you using? I’m testing this issue with the same file of your screenshot you sent me once, and it works well. I don’t get these oversized dimensions and all the dimensions appear in the DWG file. Can you share it again?
@MichalKrizo most of the bugs related to the DWG export reported since last year have been fixed. I encourage you to try it again.
Hi Francesc,
I’m using Rhino 8 SR36. I’ve also tested the latest SR36 build with VisualARQ 3.13 RC3, but the DWG export issue persists.
I also tried Rhino 8 SR37 RC, but unfortunately it crashes during startup, even in Safe Mode. The Windows Event Viewer reports a System.IO.FileNotFoundException for Eto.Wpf (Version 2.11.0.0), and the Rhino Repair process also fails.
I’m attaching the model again so you can reproduce the export issue.
The exported DWG shows the same oversized Model Space dimensions in both BricsCAD and Autodesk Viewer.
Could you also let me know which Rhino version you’re using for your tests?
Thanks!
R.
building20261029.zip (7.3 MB)
System Info
Rhino 8 SR36 2026-10-23 (Rhino 8, 8.36.26296.17001, Git hash:master @ 67b86f484e418b0eb5432b6f9733383ebb6b7caf)
License type: Commercial, build 2026-10-23
License details: Cloud Zoo
Windows 11 (10.0.26300 SR0.0) or greater (Physical RAM: 15GB)
.NET 10.0.9
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display and OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-22-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 610.88
Integrated accelerated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-22-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 610.88
Secondary graphics devices.
AMD Radeon 780M Graphics (AMD) Memory: 1GB, Driver date: 12-5-2023 (M-D-Y).
Integrated accelerated graphics device with 10 adapter port(s)
  • This device is not being used
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-22-2026
Driver Version: 32.0.16.1088
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.36.26296.17001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.36.26296.17001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.36.26296.17001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.36.26296.17001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.36.26296.17001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.36.26296.17001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.36.26296.17001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.36.26296.17001
Hi @badileanu With your new file, I’ve managed to reproduce the problem of the oversized dimensions! It looks like the problem happens with the dimensions inserted in the Model Space. We will investigate how to fix this.
PD: By the way, if you open the DWG file in AutoCAD, there’s a weird thing that happens: The dimensions don’t appear in the first moment, but they do after switching from Layout-Model View tabs. That’s something beyond our scope, but it’s good to be aware of it because it gives the impression that the dimensions are not there.
Thanks, Francesc!
Glad you were able to reproduce the issue. I appreciate you looking into it.
Thank you for your collaboration and patience in this matter. I’ll keep you posted with any news.
