No primary text entry box. Pull down the bottom and it shows up and then appears to stick for subsequent uses, even after closing and reopening the beta. This may be just some kind of dialog initialization problem… I haven’t used a dot in awhile.
Thanks for reporting, this came in with the recent Dot dialog cleanup. Font and Height moved to their own rows and the Display text box is the one that gives up the space when the dialog opens short, so it can shrink to nothing. Logged as RH-99196, resizing once like you did is the workaround for now.
