V8 script compiler issues
Trying to update my scipts for V8, and the V8 compiler has issues that I can’t figure out. Well, probably could - but one of you probably knows the answer without hours of experimenting.
The Python 3 compiler gives me a syntax error at ‘None’ at the end of the GetMultipleObjects line:
import Rhino
import scriptcontext as sc
def main():
rc, objrefs = Rhino.Input.RhinoGet.GetMultipleObjects("Select surfaces, polysurfaces, curves, subds, and meshes to annotate",False,Rhino.DocObjects.ObjectType.None)
if not objrefs or rc != Rhino.Commands.Result.Success: return
lstObjects=[]
if( name == “main” ):
main()
Change None to NONE when it is part of a Rhino-defined enum. Everywhere where None was used as part of the RhinoCommon API this had to be renamed to NONE since None is a Python3 keyword.
@eirannejad I wonder if we can just do a preprocess to replace .None with .NONE
Or at least notice the existence of .None and provide guidance
See RH-66291 RhinoCode: Accessing Dotnet member with name of “None” was invalid code in Python 3 .
Yes, guidance would be great.
Script editor does provide an error when .None is used anywhere in code:
Are diagnostics enabled on your editor? Right-Click on script or script tab and select “Language Options” nad make sure Diagnostics (Linting) is on
Rhino_KgdBPU1cHv
Yes, I’m set up like that. The editor shows that there is a syntax error, but no further guidance. If I click on Help->Help Topics, it brings me to help for Rhinoscript, so…not helpful.
I see. Okay I’ll make sure the error mentions you can use .NONE instead
RH-77801 Python lint to mention to use .NONE instead of .None
