V8 - nothing is printed
Sadly, I have to join the choir complaining about printing in V8.
First thing spotted while adjusting the print properties is that margins are still displayed even being ‘zeroed’:
Second: the file size after printing is ‘zeroed’ too:
I have the most recent updated (today’s 8.7).
Sysinfo:
Rhino 8 SR7 2024-4-22 (Rhino 8, 8.7.24113.23001, Git hash:master @ 6d95a2bfe831b9dd0ef81b6e220b294af59416ca)
License type: Commercial, build 2024-04-22
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Primary display and OpenGL: Radeon Pro 560X (AMD) Memory: 4GB, Driver date: 7-28-2023 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context FireGL 21.30.45.18 30.0.13045.18005
> Integrated accelerated graphics device with 6 adapter port(s)
Primary OpenGL: Radeon Pro 560X (AMD) Memory: 4GB, Driver date: 7-28-2023 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context FireGL 21.30.45.18 30.0.13045.18005
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 7-28-2023
Driver Version: 30.0.13045.18005
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Cyberstrak\R7\CS_ModelingPlugIn.rhp “Cyberstrak Modeling PlugIn”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.7.24113.23001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.7.24113.23001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.7.24113.23001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.7.24113.23001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.7.24113.23001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.7.24113.23001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.7.24113.23001
C:\Program Files\Rhino 8\Plug-ins\export_PDF.rhp “PDF Export” 8.7.24113.23001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.7.24113.23001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.7.24113.23001
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Named Position”
How are the results going to PDF?
Can you post a file exhibiting this and a full screenshot of your Print settings? Thanks
I wish I could show you my printing panel but it exhibits another V8 display problem - everything gets blurry:
You have to dig the file which comes as V7. I had to convert it in order to be able to print. V7 prints fine.
The file itself comes through upload.
Seeing a similar result with the RhinoPDF, everything is OK in Bluebeam or Microsoft Print to PDF settings. Thanks for reporting RH-81691
Hmmm.
What’s your theory then? Where should I look?
The youtrack will have the details as soon as the Developers can dig into it. This will be a high priority item.
Thanks.
Thanks for the update on this. I wondered if this will include other (possibly related?) issues with detail print width settings? I posted about this here: Print width not working correctly in Rhino 8 - #7 by ARC_Guitars
It’s possibly I’m just misunderstanding the behaviour but it does seem to work differently to V7. I’ve tried exporting the files I’m working on to V7 and the print width issue goes away. I’ve also tried creating a new layout and detail view in V8 but still get the issue.
