I can’t move dimensions (annotation) to a layer by rightclick on layer and choose “Move to layer”. It is locked and no command is running.
Do you have “Lock children” enabled? Dims are history objects.
Only if this is default by V8. It’s a clean install, I’ll check.
Edit: Nope, it wasn’t.
And I can change layer with the layer area at the bottom of the screen.
PS! Did you check, alas does it work on your system in V8? Or did you just respond?
Yep, this is coming… and yes it is annoying at the moment… You need to left-click select the layer before you can do anything.
