I’m doing a lot of work using BlendCrv atm where all I want is a simple blend (4 point degree 3) to go from the end of one existing curve to the end of another, tangent to both. I don’t need to “Flip” or to adjust the start point of the blend. The behaviour I’m now seeing in V8 is proving time consuming compared to the simple behaviour of the old command.
Is there any way to make BlendCrv give me that simple blend as the in-point? Or another command that will do it?
Thanks Dale. Following your post, I had a quick look around the Curve Tools toolbar and found it to be still resident there - just renamed “Quick curve blend”.
So order has been restored to my popup toolbar . Many thanks.
