I just downloaded 6Wip and tried the Mesher again after many months away from it. Maybe even a year?
It’s quite good. Not perfect, a few holes but having MODO to clean up the mesh and patch things gives a nice workable mesh to smoothen out. I’m not looking to do much in the way of editing or manipulating the mesh from Rhino…just smoothen it out nicely.
I haven’t touched the SDS tools at all.
It’s got a ways to go…I got spoiled by nPower’s quad mesher a few years ago and while this is not that, it’s certainly in the right direction.
But you know what…downloading the file wiped out my permanent version of V6 and turned it into a WIP. So now on my desktop I have ‘V6 WIP’ and one called ‘WIP’…and my permanent V6 is now gone along with all of the plugins.
So now I have 2 short cuts titled WIP on my desktop. And they both open the same V7 WIP. Though one of the short-cuts is where my Perm V6 used to be. I looked and looked on my harddrive for V6. It is now gone and replaced by a WIP.
Maybe someone at McNeel can help me find it without having to download everything again and re-install all pluggins.
It did mine. Searching produced a short-cut titled Rhino 6 but it has WIP stamped across the rhino. Basically it replaced it with a new short-cut. I can’t seem to find any reference to V6 in program files.
Anyway, I’m in-installing WIP and then re-installing V6 with plugins and will wait till the WIP becomes V7. This is such a waste of time.
That’s what’s strange the WIP changed to V7 on the same day V6 was released.
I have had both installed since then, and update them every day for my testing needs.
I do this on multiple computers to keep all the different versions and SR states available.
I’ve never see it and have not heard any other reports of it.
Something else is going on here and it seems to be unique to your system.
Hopefully, you’ll find a pattern that may explain it.
I uninstalled the WIP and ran the V6 Installer…it asked to repair the previous V6 Install which I did and everything came back. The WIP installer is over-writing something in the V6 install folder and changing it’s name.
I got it from the download page. I just ran it from there. I don’t know the name. I might try again and download it to a folder and go from there…see if it matches yours.
