Normand
(Jakob Normand)
March 28, 2019, 11:25am
1
Hi McNeel
The append command crashes every single time I try to enable “from edge”.
Regards, Jakob
Sysinfo:
Rhino 7 SR0 2019-3-26 (Rhino WIP, 7.0.19085.10525, Git hash:master @ 77b3c230a1e52fe2ce7f927415bcc0545f81cb67)
License type: Commercial, build 2019-03-26
License details: Cloud Zoo. In use by: Jakob Normand ()
Expires on: 2019-05-10
Windows 7 SP1 (Physical RAM: 32Gb)
Machine name: NIK-Z620
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce GTX 1080 Ti (NVidia) Memory: 11GB, Driver date: 3-1-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 419.35
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-1-2019
Driver Version: 25.21.14.1935
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
Rhino plugins
C:\Program Files\Rhino WIP\Plug-ins\Commands.rhp “Commands” 7.0.19085.10525
C:\Program Files\Rhino WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino WIP\Plug-ins\RhinoRender.rhp “Rhino Render”
C:\Program Files\Rhino WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.0.19085.10525
C:\Program Files\Rhino WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot8RhinoPlugin (6c7d7caf-b4ba-406d-bfaa-8d719d8212c3)\1.0.0.0\KeyShot8RhinoPlugin\Rhino 5.0\KeyShot8RhinoPlugin.rhp “KeyShot8RhinoPlugin” 1.0.0.0
C:\Program Files\Rhino WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.0.19085.10525
C:\Program Files\Rhino WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.0.19085.10525
C:\Program Files\Rhino WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino WIP\Plug-ins\Displacement.rhp “Displacement”
Hi
I also confront same problem. Today, I update newest version: rhino_en-us_7.0.20189.15345
It did not solve this problem.
I create Plane SubD>Click Append to SubD. It will make Rhino 7 NO Reponse. ESC button will not exist this command. I have to End Task.
Please consider this problem.
Me too. I had a single SubD rectangle and I had just clicked on the “Append to SubD” tool and that was it. The first Command prompt, “Select meshes or SubDs to append to:”, was displayed when it hung.
I created a dump file and terminated Rhino. However, the dump file was huge, on the order of 1.7G so that was not real helpful.
It happened again, and I tripped over something that is repeatable: while the “Select meshes or SubDs to append to” Command prompt is showing, clicking on the Help panel tab makes it hang!
pascal
(Pascal Golay)
July 9, 2020, 4:40am
4
Hi
Version rhino_en-us_7.0.20196.12025
Append tool still make Rhino 7 NOT respond.
There is same problem with Single SubD Face tool.
inju
(Inju)
July 15, 2020, 3:45pm
7
Works, rhino_en-us_7.0.20196
theoutside
(Kyle Houchens)
July 15, 2020, 3:47pm
8
fwiw, that feature is a lot easier to use in box mode-
Hi
I post my laptop specification, it may helpful:
Hi
Version rhino_en-us_7.0.20203.15405
Append tool and Single SubD Face tool still make Rhino WIP NOT Responding
Please check and fix. Thank
inju
(Inju)
July 26, 2020, 5:15pm
11
Works, version rhino_en-us_7.0.20203
Yes @inju , I saw it worked with you all time. There are someone confront problem like me.
I uninstall and reinstall many time.
inju
(Inju)
July 27, 2020, 7:23am
13
If there are installed other plugins, try to remove them.
Hi
I did not install any plugin for Rhino WIP.
theoutside
(Kyle Houchens)
July 27, 2020, 3:17pm
15
append needs an open subd to attach to…that said it should not die like that.
Just tested it here in (7.0.20204.13215, 7/22/2020) and it’s working well.
brian
(Brian Gillespie)
July 28, 2020, 11:43pm
16
RH-59459 is fixed in the latest WIP
Thank @brian and Rhino Team.
I checked today, It’s fixed!
