V7/V8 - BUG - make2D fails on section view
Hi guys,
it seams that the ITALIAN Version 7 SR36 (7.36.23346.16351, 2023-12-12) fails in making the 2D drawing of a section view.
as you can see here when I do the Make2D commando the result is an empty solid also if the geometry is shown as closed solid.
Also the ITALIAN Version 8 SR6 (8.6.24086.11001, 2024-03-26)
does strange things. In the image the Make2D works as expected while the SectionDrawing fails like the V7.
The 3D model is an imported STEP file that I made it as closed PolySrf
Any suggestion?
@rajaa are you in charge of this?
or maybe @stevebaer ?
Here’s another ClippingPlane issue:
The printed drawing shows artifacts due to the overlapping cylinder.
The viewport doesn’t shows any issue.
To me it seams related to the previous problem.
This is V8 sr6
Thanks
@skysurfer can you share the model please? It helps to test with. Also, what options you chose when ran the ClippingDrawings command. Thanks
