V7 Tutorial Inspector Panel - Files Not Available to Download
The tutorials files are not available to download from the Tutorial panel. The triangle that would normally appear to the left of the text descriptions is missing. I have V6 installed where there is no issue. I have tried uninstalled & reinstalling. Please advice.
Screenshot 2021-04-13 at 15.24.24
Thanks Sean
Hi @Sean2
I’m not seeing this here in Rhino 7.4 for Mac, I also tested in Dark mode on macOS thinking maybe that was involved but the > next to each section was still there. Can you run the SystemInfo command and post the resulting text file?
Thanks Brian…
systeminfo.txt (4.8 KB)
Thanks @Sean2 This appears to be a Mojave bug with Rhino 7. I filed this as https://mcneel.myjetbrains.com/youtrack/issue/RH-63810
You can access some PDFs and models here for now… Rhino - Learn to use Rhino and Rhinoceros Help
Thank you Brian, my V6 installation will also provide access to all files.
