V7 SR23 crash on startup
Hi McNeel
Just a heads up on the fact that SR23 crashes my PC on startup - it starts in SafeMode. I’ll go through the plugins to see if I can spot the culprit. SysInfo below.
-Jakob
SysInfo
Rhino 7 SR23 2022-9-12 (Rhino 7, 7.23.22255.07001, Git hash:master @ 586632f42bda95321d44f8ac7407b670af4e4eab)
License type: Commercial, build 2022-09-12
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 95Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro RTX 4000 (NVidia) Memory: 8GB, Driver date: 7-21-2022 (M-D-Y). OpenGL Ver: (null)
OpenGL Settings
Safe mode: On
Graphics level being used: OpenGL (null) (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Unknown
Render version: (null)
Shading Language: (null)
Driver Date: 7-21-2022
Driver Version: 31.0.15.1694
Maximum Texture size: n/a
Z-Buffer depth: n/a
Maximum Viewport size: n/a
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.23.22255.7001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.23.22255.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.23.22255.7001
Hi Jakob -
That doesn’t look good.
Had a Windows update?
That is because safe mode.
Yes, correct.
-w
Hi @wim
OK - I see that @nathanletwory beat me to it. It’s usually working fine :slight_smile: But updating the driver as we speak to see if that helps :slight_smile:
-Jakob
Hi Jakob -
I take it that you let Rhino update automatically?
I’d look in
C:\ProgramData\McNeel\McNeelUpdate\DownloadCache
for the previous version that you were running and see if that now crashes as well.
Hi @wim
Can confirm that SR22 works as expected, so something in RC23 is making my machine choke. I see there’s an update for VisualARQ - will get that installed and try RC23 again.
-Jakob
Hi again, @wim
Sorry for the semi-false alarm - updating Nvidia driver and VARQ seems to have done the trick. I don’t know if you can tell from the crash reports, which was the offending party this time.
Thanks for reminder on the DownloadCache folder - I had quite forgotten that previous installers can be found there. It now has its own shortcut on my desktop :slight_smile:
-Jakob
Edit So what I’ve got running now is 7.23.22255.7001, 2022-09-12.
