V7 on old system w/ 2 GB video memory
My desktop system dates to 2012 and only has 2 GB of video memory, not the minimum 4 GB recommended for V7. It does have 16 GB of memory. I have been running V7 without problems other than with multiple very large shaded meshes (millions of faces) rotating and panning the view can lag substantially. Below are the Holomark results for the system and SystemInfo.
Holomark 2 R6 v2,61
Total Score: 52010
Total Runtime: 207.92 sec
GPU scores: 39910
GPU_01 - 107.50 fps - Cube 4 tests
GPU_02 - 54.10 fps - UDT Shape
GPU_03 - 434.80 fps - Wireframe
GPU_04 - 151.50 fps - Shaded
GPU_05 - 52.90 fps - Rendered
GPU_06 - 55.20 fps - Block Rendered
GPU_07 - 116 units Nurbs @ 5 fps in Wireframe
GPU_08 - 43 units Nurbs @ 5 fps in Shaded
GPU_09 - 33 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 58.80 fps - RenderMesh Render
GPU_11 - 192.30 fps - RenderMesh RenderSpeed
GPU_12 - 133.30 fps - JoinedMesh Render
GPU_13 - 322.60 fps - JoinedMesh RenderSpeed
GPU_14 - 8 units mesh @ 15 fps in Shaded
GPU_15 - 40 units mesh @ 15 fps in Render
GPU_16 - 47 units mesh @ 15 fps in RenderSpeed
GPU_17 - 49.30 fps - mesh in Rendered Studio
GPU_18 - 16.20 fps - Nurbs in Rendered Studio
GPU_19 - 37.50 fps - Block Illustration
GPU_20 - 156.00 fps - 2D single
GPU_21 - 59.80 fps - 2D massive (20x)
CPU scores: 12100
CPU_01 - 6.56 sec - Booleans and Contours
CPU_02 - 3.52 sec - Twist and Taper (UDT)
CPU_03 - 8.73 sec - Meshing Mini
CPU_04 - 0.08 sec - Extract Render Mesh
CPU_05 - 0.03 sec - Join Render Mesh
CPU_06 - 17.16 sec - Reduce Mesh
CPU_07 - 1.33 sec - Calculating Technical display
CPU_08 - 3.91 sec - Making Silhouettes
Hewlett-Packard
h9-1185
AMD Radeon HD 7700 Series - 2048.0 MB
DriverVersion: 27.20.1034.6
Intel® Core™ i7-3770 CPU @ 3.40GHz
NumberOfCores: 4 NumberOfLogicalProcessors: 8
MaxClockSpeed: 3.4 GHz
TotalPhysicalMemory: 16.0 GB
Microsoft Windows 10 Home
  • None - 64-bit
Rhino 7 sr 5 64 bit
AA level = 4
Rhino 7 SR5 2021-3-9 (Rhino 7, 7.5.21068.13001, Git hash:master @ 76e41732e41ab44776e5ac3fa043f38d54440011)
License type: Commercial, build 2021-03-09
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: AMD Radeon HD 7700 Series (AMD) Memory: 2GB, Driver date: 8-21-2020 (M-D-Y). OpenGL Ver: 4.6.13596 Compatibility Profile Context 20.10.35.02 27.20.1034.6
> Accelerated graphics device with 8 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 8-21-2020
Driver Version: 27.20.1034.6
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Orca3D V2\Orca3D.rhp “Orca3D” 2.0.20.0
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Holomark2_R6 (6733c793-b8cd-f362-2097-bda699f6f4ac)\1.0.6927.1052\Holomark2_R6\Rhino 6.0\Holomark2_R6.rhp “Holomark2_R6” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.5.21068.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.5.21068.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.5.21068.13001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.5.21068.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.5.21068.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.5.21068.13001
Hey @davidcockey,
Another benchmark you might consider running if you looking to compare your hardware.
– Dale
