often would be usefull simply open a group, modify objects and reclose the same group of objects.
Now we have to do: remove to group, select (often a lot of objects), modify objects, reselect objects, add to group.
Thanks
There is a command _AddToGroup. Anyhow I suppose you refer to a grouping method such as in Adobe Illustrator- I have added it to the wish list. http://mcneel.myjetbrains.com/youtrack/issue/RH-34785
I think yes. I have in mind something like 3ds max.
Thanks
Yes I have missed this as well, itâs a command in 3dsmax âopen groupâ. It would enhance groups and make them easier to control in addition to the current commands of add to group and remove from group.
RM
A group can be selected using SelGroup.
Indeed, much like an inplace block edit
All other geometry is frozen and you can work âinsideâ the group only.
-Willem
Do you know that you can select individual items within a group using Control+Shift+Left Click on any element? It is not as elegant as in Illustrator or SketchUp, but itâll save you from exploding the group.
José, you open me a new world
Thanks
Also works on polysurfaces and other "composite"items.
But not on polylines and polycurves (joined curves) unfortunately.
You are welcome ; )
In V6 it will (if Iâm not mistaken )
