V6 Viewport properties not linked up yet, need wallpaper
Hi, the wallpaper function in V6 is not accessible as viewport properties are not enabled. Can you please fix this? (I work around it by saving as V5 and then do the object and camera matching there, but that messes up materials, so it’s not a good workaround)
Wallpaper should work already in V6. Set an image in properties tab for view. Then for Rendered (and Raytraced) mode you have to set Backdrop to Wallpaper in Rendering panel still.
/Nathan
