On V5, the height for the text command was the last set height. It would also retain the last text string.
On V6, the text height resets to 1 every time. The text resets to “” each time.
I the previous behavior was more desirable.
That’s because the text height setting is added to annotation styles in v6. You can set the default text height in annotation styles.
This had just been fixed yesterday in RH-55689. The fix will be in 6.21.
