V6 SR4 RC1 problem - constant "Transforming subobjects... Press Esc to cancel"
Just installed the latest SR4 RC1. Every object I touch and move/nudge, results in Rhino printing that to the command line resulting in major slowdown. Something is wacky here…
“Transforming subobjects… Press Esc to cancel”.
Hi Jarek - I did not see this at any point in the SR4 testing so far - I should say I did not notice it - but I did test this today, which might have been a recently introduced then fixed bug
https://mcneel.myjetbrains.com/youtrack/issue/RH-45283
Hi Pascal - to clarify - it happens with regular objects, i am not touching any subobjects at all.
EDIT: @Pascal - here is how it looks:
In case that may be connected, by default we have the TestToggleSubObjectSelect set to DISABLED.
Sub-object selection with Control+Shift disabled. But this problem happens both when it is enabled or disabled.
Hi Jarek - sorry for the delay - I see this in the latest build here now as well.
https://mcneel.myjetbrains.com/youtrack/issue/RH-45386
