Hi Jim - so far I do not see what you’re showing - can you please export the display mode from “Options > View > Display modes” that is in use for your screen shots and send me that or post it here?
One other thing…it seems to act differently with different camera lens lengths. I had a lens set to 18mm and it was definitely noticeable and then when I changed it to 55mm less so. I’m right clicking on my mouse to move the viewport into position and even that, depending on where I stop, seems to effect whether I see lines or not.
Must be on my side…when I capture the file and look at it, it doesn’t have the visible lines…but the display shows it – here’s a screen capture of the same thing.
Hi Jim - please try hiding the cut-out figures that are behind the camera, as well as anything else that is not in the view. Does that make a difference?
Yes it does make a difference. I eliminated the cut out figures behind camera. I also noticed a straight line running out of camera view. When I deleted the line on the ground plane, the see through lines on the unit were no longer see through.
Hi Jim - it does not have the same bleed-through effect here, but if you turn on the camera (F-6) for this view in a 4view setup I bet you see that when the line comes into the camera frustum is when you see the bleed-through - I think, especially with a short lens, the depth sorting is suddenly asked to deal with a much bigger spatial depth when the line comes in, and the precison of the sort drops off.
