V6 rectangle light manipulation
would be possible manipulate rectangle light with control points through points in light corners (and center)?
I have checked "Allow selcting objects with points on" and "Tunr on control points when selecting a curve, light and annotation"
But with light is impossible manipulate through corner and center points.
When i disable _“Tunr on control points when selecting a curve, light and annotation” then is all OK.
As far as I can tell there are no control points in corners. There control points (grips) exist on two of the edges, and then there are three other grips: light target, light dolly, light location.
See this…
I think that is be possible to select corner points with checked choice "Allow selcting objects with points on"
I think you are referring to object snaps here. @pascal?
Yes, object snap maybe…you are right.
Hm - yeah, it does seem odd that Point osnap turns up at the corners but you can never see them as points of any kind… I’ll ask.
something new with this problem?
