I’ve tried methods used in other threads. Is there a current way to have an Incremental Save Small in V6 that works?
I’ve tried setting the options with the - on the command-line, but then after it ( doesn’t ) save small.
Thanks,
–BrendaEM
Thanks,
–BrendaEM
Hi Brenda - as far as I can see-IncrementalSave
includes SaveSmall=Yes/No - are you saying that setting this to Yes does not actually save small?
It appears to save small–once.
Not being distracted by anything, was one of the virtues of the save small button.
[It might be possible to write a button script that also 7.zip’s the Rhino file. Rhino files generally 7zip compress down to 20% of their original size.]
