When I’m drawing any line or object and click enter they disappear from the canvas. I can not see it but I can select it or activate the control points.
If it is a line, I can change the type of line in the layers and then it´s visible. But I can´t make other geometries visible.
This sounds like a problem with your display driver. Please run the SystemInfo command in Rhino and post the results here. That will help me figure out what is happening
Thank you in advance for your help.
Here is the SystemInfo:
Rhino 6 SR5 2018-6-4 (Rhino 6, 6.5.18155.13161, Git hash:master @ 0e00e118078ee9a651d609817f672fb0ed8e83bf)
Licence type: Comercial, revisión 2018-06-04
License details: Cloud Zoo. In use by: Ismael joyeros ()
Windows 7 SP1 (Physical RAM: 7.5Gb)
Machine name: ISMAEL-PC
GeForce GTX 660/PCIe/SSE2 (OpenGL ver:4.3.0)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.3
Shading Language: 4.30 NVIDIA via Cg compiler
Driver Date: 6-21-2013
Driver Version: 9.18.13.2049
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
This is most likely the problem. I would try seeing if you can get an updated driver for your video card from nvidia
I´ve already updated the driver and the problem it´s solved.
Thank you very much for your help.
Hello, I might be having a similar problem: My point layers do not show up in the viewport (e.g. when I select objects form the table of contents it says “X objects selected” but they do not show up, like if the layer was turned off). Curves show up with no problem.
After SystemInfo check, I see my driver dated to 2011 (running Rhino6 in a windows 7 OS).
How can I update the driver? what kind of driver is needed to update and how?
Thanks!
R.
