V6 Display Performance: Block Improvements
Objects moved to 0,0,0 - problem is still there. Added a split - split edges are looking fine, touching edges of the model still bad.
Hi @stevebaer
I have tested latest WIP.
One reported issue is fixed (39428)
But the issue indicated earlier (#6) still is not solved.
I will try to prepare a clean example.
Thanks,
Dmitriy
Models with heavy blocks now display properly, even in shaded modes with transparency, and strange artefacts that I reported by message are now gone (6.0.17143.8371)
I’m really happy of what I’m seeing here.
On the grasshopper side, there seems to be some trouble though.
When I open my definition, I get a stream of display pipeline warnings…
Hi @stevebaer
Please see example below.
Block becomes invisible when I freeze the layer, the block objects belong to.
BlockTest_ToSteve1.3dm (242.4 KB)
Thanks,
Dmitriy
Hi Dmitry - I see that, thanks.
https://mcneel.myjetbrains.com/youtrack/issue/RH-39580
@DavidRutten, have you seen these error messages? Sounds like it is GH specific
Can you upload this definition?
Sent to David
3 posts were split to a new topic: Dark Blocks
I just installed the latest WIP update for Rhino 6 and I am no longer seeing any curves. I opened up a mesh file and was able to see curves there, but in wireframe and in any other mode, like ghosted, I cannot see any NURBS curves or isocurves belonging to NURBS surfaces
Hi Danielle - can you please run SystemInfo and paste the results here?
thanks,
Rhino 6 SR0 2017-9-19 (Rhino WIP, 6.0.17262.13121, Git hash:master @
b8e026a9dd4d75945f767d2004f39144d076b81c)
Windows 7 SP1 (Physical RAM: 16Gb)
GeForce GT 750M/PCIe/SSE2 (OpenGL ver:4.4.0)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.4
Shading Language: 4.40 NVIDIA via Cg compiler
Driver Date: 12-24-2013
Driver Version: 9.18.13.3228
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino WIP\Plug-ins\Commands.rhp "Commands"
C:\Program Files\Rhino WIP\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino WIP\Plug-ins\RhinoRender.rhp "Rhino Render"
C:\Program Files\Rhino WIP\Plug-ins\rdk_etoui.rhp "RDK_EtoUI"
C:\Program Files\Rhino WIP\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino WIP\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino WIP\Plug-ins\CyclesForRhino.rhp "Cycles for Rhino"
C:\Program Files\Rhino WIP\Plug-ins\RhinoCycles.rhp "RhinoCycles"
C:\Program Files\Rhino WIP\Plug-ins\Toolbars\Toolbars.rhp "Toolbars"
C:\Program Files\Rhino WIP\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino WIP\Plug-ins\Displacement.rhp “Displacement”
First things first - update these drivers to a more current version.
Sometimes the blocks are not visible in parallel views. Have any suggestions?
A post was split to a new topic: Block visibility change
