changing the current active layer is very slow in V6. Looks like the delay depends on the count of layers in the file. With 700 Layers it takes about 1 second to change the current layer, which feels way too slow.
Is this something which can be improved?
Do you recommend to consolidate my explicit layer hierarchy?
i’ve tested with a file having 3573 layers. The layer structure is nested, under one root layer there are 20 other layers, then the rest ist nested within 3-5 more levels. If i switch the current layer, it works instantly on layers which are either empty or do not have many objects. But i see a slight delay (approx 0.5s) when there are many objects on the layer to make current.
Do you get the delay always, regardless of the amount of objects on a layer ?
Hi Clement,
Thanks for investigating! Okay, does not seem to be the case with all files.
Can you repeat it with the attached file? CurrentLayerDelay.3dm (853.9 KB)
Hi Jess - that is slow here…
It looks here, like making a green ‘Vertical’ layer current is noticeably slower than making a red , ‘Horizontal’ one current, though both lag. The ‘Nut’ layers are instant. https://mcneel.myjetbrains.com/youtrack/issue/RH-44478
