I’m getting this kind error with RhinoCommon on Rhino 5 too !
Just calling GetSubObjects() on an InstanceObject raises a DocumentControlledException.
Hi @Alexandre_Beaudet, can you well us more about what you are trying to an why? Perhaps we can suggest an alternative to this method.
– Dale
Hi @dale
I was trying to get the meshes contained in an instance definition.
However, I retrieve the instance definitions from document.Objects
which are RhinoObject
s.
I thought the method GetSubObjects
would give me the meshes or subinstances if the object type was ObjectType.InstanceReference
but the only object I received was an exception
I managed by casting the RhinoObject
to an InstanceObject
and then calling GetObjects
on it. It works as expected now
I’m curious though ; why would that method systematically throw an exception ? And what does that exception would mean ?
Thank you !
Alexandre
Because it is incorrectly written…
– Dale
