V5 Hatch Scale Problem
Hi
I use a hatch from autocad Ar-Conc, I am sure a lot use it.
I have used it for years
I now find that V5 is returning a zero scale
(I WOULD UP LOAD A PICTURE IF THIS DAMN SITE WOULD LET ME ( NEW USER AND ALL THAT CR@P)
It also will not let me change the scale to 0.0005, I use a different scale on the Title sheet
John
Hi John,
I was able to recreate the problem with any Rhino hatch, in model or layout.
The hatch scale does seems clamped at .001.
Could be a bug or by design. I will ask the developer and let you know.
If you are doing a legend you could work around this by taking a ScreenCaptureToFile of a viewport that shows the hatch. Then edit the image to just the hatch, and use PictureFrame to place the image of the hatch on the title sheet.
Thanks,
Sincerely,
Mary Ann Fugier
McNeel Technical Support
Seattle, WA
