Generally speaking perhaps, however, when you do encounter issues, I have found it worthy to first try exporting all the formats the target application will import. Occasionally, if something craps out in one format, it might be ok in another…and if the target app reads .3dm be sure to try that too.
Hi Brenda- I see that- the sprocket is exported to the block definition location. Try ExplodeBlock on this for now, before exporting, and see how that works.
The sprocket is one of hundreds of blocks. If there a macro to explode all, it would be doable.
I feel feel bad because he people who received this file are real Solidworks snobs, and this might be the first contact they had with Rhino geometry, if you know PR wise what I mean.
Also, currently .stp is the best hope for file compatibility with the open source projects Solome and Freecad3D
Gee, it would sure be swell, if this were fixed.
-brenda
