Hola, no puedo cambiar el tamaño horizontal de la ventana V-ray options. ¿A qué se puede deber?
Estoy trabajando con parallels en mac. Y la version es rhino 5, v-ray 2.0.
Muchas gracias.
Muchas gracias.
In other times I could adapt the window to the content. It´s important for me because I can´t see all options and it´s very slowly for work…
I attach you a photo of my problem.
I can´t understand…
Thank you very much.
Carlos Sanz
Hi @carlossanz,
this looks like a bug to me, the window size should be wider, without horizontal scrollbar. Is this happening on Windows 10 ?
@matt_newberg, do you have a suggestion ?
c.
Hola Clement.
Yes!!It´s happened on Windows 10…
I can´t imagine the solution… One time I got the solution, but I don´t remember what I did.
I continue trying…
Thank you…
Did you change any font size in windows maybe ?
c.
I have a solution. My problem it was the screen resolution. Icon size it was 150% and recommended resolution. I have changed the resolution from 2880x1900(recommended) to 1920x1200 and the icon size to 100%.
I´m crazy with parallels and windows 10 in mac…
For now it´s ok!
Thankss
