I am having an issue pushing the vrayscene/geometry to rhino for a vray rendering. The is error: “1. Solution exception:Method not found: ‘Boolean VRay.VRayRenderer.RemovePlugin(System.String)’.” Attached is the gh file. The script is simple enough; i’m testing out the .vrayscene import with grasshopper, but not sure where this issue is originating.
Has anyone come across this issue?
Any help is very much appreciated.
Thanks,
Joel
vray scene generator.gh (7.0 KB)
— solved - vray components from v5 were brought into the components library for rhino v6. once I removed them, the script works well.
