Hi, this is just a small nit-pick that I think may however improve the ease of use of Grasshopper.
Background & the problem:
I don’t use Grasshopper every day but every once in a while I find myself figuring out what the format is that Grasshopper components accept as their parameters…
I tried to deduce the proper format from the Grasshopper component description (the mouse-over floating popup) but it still took me 7 guesses to get it right
Question & suggestions:
Is there something like a syntax reference card/cheat sheet? If not, it might be useful to have one easily accessible somewhere in the GUI
The more elegant solution IMHO would be to fix the wording of hints used inside Grasshopper and/or match the components behaviour to accept what the GUI suggests.
Example:
this particular hint says: {uv} coordinate to evaluate
while in reality it only accepts {u,v,w}
- where w
can probably be only 0. Obviously the values need to be separated but the hint does not say how either.
