I am brand new to Rhino (using it for about 3 weeks). I imported a STEP file, which is a polysurface.
I am trying to apply a seamless texture and do UV mapping. When I try to join the UV map in the UV editor, some parts join together perfectly, but other parts stay unjoined/separated. I have attached a close-up screenshot showing where the texture looks broken at the seams.
What is the correct way to fix these unjoined seams on a STEP polysurface so the texture flows smoothly? Is there a faster way to map this 1:1 without manual unwrapping?
Hi @Rochelle
Welcome to the Rhino Forum
STP-files hold no UV-information at all, so when importing a STP-file all you get is the default surface mapping. Depending on the shape of the polysurface (which is hard to tell from screengrabs alone), you can either go for one of the build-in mapping types (planar, box, cylinder etc.) or manually unwrapping it, using the Unwrap command to designate seams and the UV Editor to line them up, transform them etc. Please post a 3DM file if you need further help - screengrabs seldomly convey the full picture, so to speak.
HTH, Jakob
Thank you for the quick reply! Unfortunately, I cannot share the 3DM file because the project is strictly confidential.
I did try the Unwrap command by adding seams, but I am struggling inside the UV Editor. My texture contains icons that need to be an exact size for printing later, so I cannot have any stretching or distortion.
Inside the UV Editor, what are the best tools or options to prevent texture stretching and cleanly join the broken edges? Also, are there any specific tutorials you recommend for UV mapping complex polysurfaces at an exact 1:1 scale?
Thank you for the video link! The tutorial was incredibly helpful. I went back into the UV Editor and used the edge straightening and pinning tools. The texture is now joining much better in the areas where it was broken before.
I appreciate the guidance! I was just wondering out of curiosity if there is an even faster or more automated way to unwrap complex polysurfaces like this in the future, or if manual edge pinning and straightening is always the standard path for precise 1:1 scaling?
Thanks again for the help, I really appreciate it!
