I’ve put a picture material on one surface of a cube. I need to adjust the proportions and can’t figure out how to access control of the uvw map for just that surface.
Thanks,
Dennis
Thanks,
Dennis
Hi Dennis - yeah, you do not get mapping control of sub-objects - I guess you need to extract it.
I was able to do some adjustments by first applying a planar map to the whole object. Then I rotated the Cplane to match the surface I was working on. Next I ctl+shift clicked the surface I wanted to map, then applied the picture material. With the sub-object still selected, I turned on the mapping widget and adjusted the map as needed. Worked fine for that one surface. I don’t know if this would work on multiple surfaces on the same object yet.
