UV map problem after export
unhandled
#1
Hello and thanks for support
this screen is mesh correct UV map from 3dm file
this screen is mesh wrong UV map after exporting OBJ file
what am I doing wrong?
(David Eränen) #2
Hi @Tom_Tower,
This is a known bug: https://mcneel.myjetbrains.com/youtrack/issue/RH-32866.
I will discuss this bug with @Jussi_Aaltonen on Monday.
-David
#3
Thanks for answer David,
winting for :slight_smile:
#4
Hey there, any news?
(David Eränen) #5
@Tom_Tower,
We worked on this for a few hours today. It’s very tricky - we’ll get back to it tomorrow.
Thanks for the patience :slight_smile:
-David
#6
thank you very much much,I was going crazy:)
(David Eränen) #7
@Tom_Tower,
Could you attach the 3dm which contains the model with the correctly unwrapped UVs?
Thanks,
-David
#8
yes sure
http://www.monsterbashpincab.com/wp-content/uploads/2018/03/slimer-new-4600-uv-001.rar
#10
@DavidEranen
any news?
(David Eränen) #11
@Tom_Tower I am not able to open the file you attached. Can you send it as a 3dm?. I already tried fixing this bug but it proved not completely fixed. That’s why it would be great to have your model to test with.
-David
(David Eränen) #13
@Tom_Tower nevermind, the file works for @nathanletwory.
(David Eränen) #14
I can still repeat the bug using your model. Thanks. Here is the YT item: https://mcneel.myjetbrains.com/youtrack/issue/RH-32866.
-David
